LED Squareme White LED Square Mini Recessed Light with 2700K Warm White
- Perfect for ceilings, under cabinet and wall niches. LED Miniature Recessed Downlights offer a super low profile and die cast aluminum trim with a 25 cutoff angle for comfortable general and task lighting. - Die cast aluminum construction trim, available in multiple finish options. Black solid steel housing included. LED lamp and insulated wires are pre-installed within housing, wires lead out through the side of the housing for connection to remote driver. - Two heavy gauge inner retention clips push out onto mounting surface to firmly hold fixture in place. Accommodates surface up to 3/4in thickness and 2.5in cutout. Approved for use in non-IC ceiling applications. Sold as new construction, may be re-configured as a remodel on the field. - Remote (LD-700MA03-EDIM-IS, or LD-700MA09-EDIM-IS) or plug-in (LED-700MA12-P) driver required and sold separately. Up to 3 fixtures can be installed on a 9W remote driver. Available in adjustable, Downlight, round, and square trims. - Smooth and continuous dimming to 10% with an electronic low voltage (ELV) dimmer. - High Powered LED: Color Temperature: 2700K, 3000K, 3500K, or 4500K, Rated Hours: 100,000, Voltage: 12V, Power 3W, comparable to a 20W MR11. - Bulb Shape: LED Module - Beam Spread: Narrow - Rated Life in Average Hours: 100000 - Wire Length (Inches) : 36 - Shade Glass: Frosted Glass Lens - Shade Material: Glass - Shade Color: Clear - Hardwired - Warranty: 5 Years Functional, 2 Years Finish - Bulb (s) included. WAC Lighting - HR-LED271R-27-WT
Click for Best Price »
Price comparison
Store Price
Bellacor [show price]
LED Squareme White LED Square Mini Recessed Light with 2700K Warm White Review
First WAC Lighting I've owned in years and wished it hadn't taken so long. Very happy with my choice. LED Squareme White LED Square Mini Recessed Light with 2700K Warm White is a great choice of trim.
Read more reviews »
