Motorcycle helmet constructed with A.F.C.S (Advanced Fiberglass Composite Shell) for lighter weight and increased impact resistance Features the Air Strike ventilation system with adjustable and strategically placed intakes vents combined with rear exhaust vents and integrated cooling channels in the EPS (Expanded Polystyrene) liner to provide maximum air flow through the helmet Cool-Core lightweight; moisture wicking fabric liner keeps the rider dry and comfortable Liner is removable and washable The All Clear sight system is an optically correct; anti-scratch; fog; and UV resistant face shield providing clear vision and protection Lock 'N Load shield replacement system offers a quick release lever allowing for quick and easy tool-less shield changes Lockdown shield security system consists of a single action locking mechanism allowing the face shield to be locked in a closed position The Double 'D' D-Ring retention system secures the helmet in place using standard D-rings and strap A retention snap secures the excess strap Meets or Exceeds DOT and ECE 22-05 standards Note: Comes standard with a clear faceshield. Optional tinted faceshield shown.
Store | Price |
Chaparral Motorsports | [show price] |
Best quality at best price of 249.95, you will not need any other helmets. Count on it!
